Nitrous Works Plate Limits?
Old Oct 28, 2008 | 07:01 PM
Meen95z's Avatar
Question Nitrous Works Plate Limits?
I been reading that in the nitrous works lt1 kit, the solenoids are the weakest link, but are rated 75-175.. If I put the NOS Big Shot solenoids on there and took out the nitrous works ones could I run a 200 shot? Or would it be a bad idea? And would I gain anything on the 175 with the NOS solenoids over the small Nitrous Works ones? Any help would be great, Thanks..
Old Oct 29, 2008 | 09:01 AM
Ray@NitroDaves's Avatar
I would suggest contacting Nitrous Works directly to determine the flow rates of their parts.
Old Oct 30, 2008 | 11:47 AM
slomarao's Avatar
i wouldnt go past the 175. After that you want to make sure there is very good cylinder distribution. By reading the plugs you could maybe go 200 but there is very little to gain on 25 more hp vs. the risk of going too lean.
Have you thought about maybe a two stage setup? It may be the ticket if you dont want to do direct port.
Chet1185
Feb 4, 2015 09:51 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
