Nitrous basic set up?
Old Jan 31, 2008 | 01:09 PM
  #16
2000GTP's Avatar
Originally Posted by LSWHO
I had the Zex dry kit on my GTP. Worked perfectly. 75 shot dropped me 8 tenths in back to back runs.
The jet installed into the throttle body after the screen but before the tb blade. I had a DHPv1 at the time and it never upped my timing so I didn't worry about pulling any. I didn't have ANY safety stuff at the time... I knew it was dumb, but I didn't care then either. A motor swap was welcomed and it only takes 6 hours to do one on those cars with a cherry picker and hand tools.
I might look into that kit, sounds like it is pretty easy to install and setup. I will give the Grand Prixs credit, it is alot easier to work in that engine bay then it is on the f-bodies.
Old Jan 31, 2008 | 01:13 PM
  #17
LSWHO's Avatar
Yeah, I did the install in two seperate steps (at my leisure) and it took WAY less than 2 hours to install. I think it was around 20 minutes!
HectorM52
Jul 30, 2017 11:46 AM
camaroguy50613
May 27, 2016 09:00 AM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
