Need Help Quick pt. 2!
Old Aug 6, 2003 | 06:28 PM
reuter's Avatar
hey im runnin the line from the schrader valve to the fuel solenoid. disconnected what i thought was the schrader valve but its... well... look at the pics. is this the S valve? what am i supposed to do with all those wires hanging off of there? was that whole thing supposed to come out? wheres the valve i need to remove? im in the middle of the install and about to flip out and kill someone please help. pics:
Old Aug 6, 2003 | 06:30 PM
reuter's Avatar
<venting> also the f$@%ing jerk that sold it to me conveniently forgot to include the line that runs from the solenoid to the schrader valve. is this just a regular 4AN fitting w/ SS line? is it male on one end, female on the other? sorry for all the questions. thanks guys.
Old Aug 6, 2003 | 06:55 PM
JSK333's Avatar
If you have a regular NX fuel noid, then yep, you need a 4AN line. But, I'm pretty sure the noid has a female fitting on the IN side, so you will need male connections on both ends of the 4AN line. Check first. The fuel rail side will definitely need a male connection on the supply line.
Old Aug 6, 2003 | 07:54 PM
reuter's Avatar
yea but where is the schrader valve located? i was just told what i pulled out was not the schrader (yipee) and that it is not in the center underneath the fuel rails like on ls1s. wheres it at and how can i clearly identify it?
Old Aug 6, 2003 | 09:28 PM
JSK333's Avatar
If you look at your fuel rail from the front of the car, it's on the rear of the rail to the left of the FPR. It will have a small black cap on it. You unscrew the cap and then remove the valve with a tire stem valve removal tool. Then you can connect your hose to the fuel noid.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
