N20 guys, need some general advice
I found the kit, I'm paying 992 for it w/ taxes, this is what it comes with:
Nitrous Express Nitrous Kit for LT1
Nitrous Express Fully Automatic Bottle Heater
Nitrous Express Fuel Pressure Safety Switch
Nitrous Express NHRA Legal Pressure Relief Valve & Blow Down Tube
Nitrous Express Nitrous Filter
Nitrous Express Nitrous Pressure Gauge
Nitrous Express Nitrous Purge Kit
MSD RPM Window Switch
8 NGK TR6 Spark Plugs
What else do you guys recomend I buy? I plan to spray a 75-100 shot. My suspension is bone stock, exept for the tranny mount, is this going to cause a problem? Also before you bought your kit did you feel a little uneasy?
93 T/A
Silver ZR1s, 1LE Elbow, MTI Cold Air, Flow Master cat back, 160* T-Stat, B&M Super Trans Cooler, Power Slot Rear brakes, ES Trans Mount
93 T/A
Everyone is a little nervous the first time they play with nitrous. You'll get over it real quick!
It looks like you're pretty well covered. The only thing I'd add is a good ignition system. Something with a built in rev limiter and maybe even timing retard. And once you start spraying more than a 100hp shot, (which you will). Think about upgrading your fuel pump.
Mario,
White 94 Z28
Yeah I got a few mods
Video
Black 87 IROC-Z
Mario,
White 94 Z28
Video
Black 87 IROC-Z
I had a long reply typed out and then my computer took a dump on me. I dont want to type it all again so here it is. all the for under 1k is a pretty fair price. but a lot ot that is glitter and fringe. autolite 104 are just as good of plug if not better and cheaper. you can make a purge out of used parts for much much cheaper and it will serve the same purpose. "I think the guy who invented the purge just wanted to up his nitrous sales." If you mount you bottle between your back seets you will not need a remote opener same goes for if you yank you back seat and install it there. if you are getting a N20 pressrue guage there is not need to spend the extra money on a automatic bottle heater just watch the guage. With and A4 I would pass on the window switch just use a push button and watch your tach. NX make a very good product. I used to run a NOS I replace the noids 4 times now i have an NX and have never had a problem. If you save all these cost you can get an inline fuel pump and an ingition. Which will probbaly leave you better off.
