My engine builder says.....
Went to the machince shop to see what my final compression ratio on the motor is today and then asked him how big of a shot he felt his work could take. " 100 shot is pushing it becasue we didnt clearnce it"?. What the hell ive made severel pulls on 150 jets on the stock shortblock? My new longblock consists of this. 355ci,Stock crank turned and polished, eagle billet four bolt mains with arp studs, 6" forged Eagle h-beams with arp studs(block clearenced), srp forged flat tops,chromoly top ring, cc306, OEM timing set, Stock heads redecked with comp 918 springs and hardware,Comp 1.6 RR, TF guideplates,ls7 lifters,TF pushrods, felpro 1074 head gaskets, arp head bolts, lightly ported lt1 intake with 58mm TB. Final compression ratio is around 11.5:1. I was planning on ripping the 200's through this motor. What do you guys think?
Im going to call him in the morning to see exactly what rings and gap they used. To be honest im kind of bummed to only be running 100 pills through it, with stock heads ill be lucky to see 350rwhp NA so im prob looking at 440-460rwhp on the juice. I figured i would be able to run 200 through it and not think twice, I just hope this wasnt a $3,400 mistake.
