MSD Window Switch Install?
Old Mar 15, 2004 | 07:37 PM
curt96ws6's Avatar
I have a MSD Window Switch that I want to install on my 99TA. Does it have to be modified for a LS1 or will it work without any modifications. What is the easiest way to hook it up? If I install the Window Switch, do I still have to install a Wide Open Throttle Switch? Any help will be greatly appreciated.
Thanks,
Curt
Old Mar 15, 2004 | 11:55 PM
NXz28's Avatar
Even with a window switch you will still need a WOT switch or something to control when you want to start spraying nitrous. The window switch simply controls in between what rpm range you want to spray, for ex: 3,500 - 5,000...
Old Mar 16, 2004 | 10:25 AM
curt96ws6's Avatar
Got it. Where do I hook the wire for the MSD Window Switch? It says to hook it to the TACH or the - side of the coil. The instructions are generic (not LS1 specific). Thanks for the help.
Curt
Old Mar 16, 2004 | 11:16 AM
NXz28's Avatar
I have an lt1 so i don't know, but if you call msd tech support they will let you know. You might also want to do some searches if anybody has asked this before...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
thenewkid
Nov 27, 2014 09:41 AM
