Mounting MSD digi-window switch
Old Jul 5, 2007 | 07:02 PM
xdamagedx's Avatar
How do they expect you to do this? I have mine zip tied in, but it's kinda ugly. They have the 4 rivet holes in the corners but they're only like 1/8" I.D. Do they expect it to lay flat on something and be double-sided taped down? Or is there something I'm missing here? It WORKS how/where it's at, should I take that and be happy?
Old Jul 5, 2007 | 08:04 PM
northdakota93z28's Avatar
i have mine here and it is going in tonight im not sure where i will put it but when i do i will post a pic. and what is your on off. i am going 3000 5800 and we will c how that goes.
Old Jul 5, 2007 | 08:22 PM
xdamagedx's Avatar
It's on at 3000 and off at 4200 because my car shifts at like 4500 when I'm WOT. Now that I put that into words it doesn't look like a very good window, kinda small...
Old Jul 5, 2007 | 09:13 PM
i lost my directions for the digital 6 which wire is the tach wire for the window switch?
Old Jul 5, 2007 | 09:22 PM
xdamagedx's Avatar
white
Old Jul 5, 2007 | 09:26 PM
Boosted_Z28's Avatar
The white wire is the "signal input"
Link to directions: http://www.msdignition.com/pdf/8969_frm25515.pdf
Old Jul 5, 2007 | 10:30 PM
i dont have a digial rpm switch, i just need to know what wire to connect my tach at the rpm switch to the digital six
Old Jul 5, 2007 | 10:40 PM
Then try this link: http://www.msdignition.com/downld1.htm
Old Jul 5, 2007 | 11:15 PM
is it the peg on the side that i connect to the tach wire on the rpm switch?
HarleyZ28
Oct 5, 2015 06:23 AM
dylan1303
May 22, 2015 12:24 PM
Jul 4, 2005 05:00 PM
MichiganSkip
Aug 31, 2002 08:52 PM
