Melting Plugs?
Melting Plugs?
I have used the 150 shot several times with a stock motor,
I have since, Built a forged bottom end, I ran the 150 shot fine, for several times, I then upped to 200, sprayed a couple times, And on like the 3 rd time, I melted some plugs....2 & 4
I havent sprayed since till the other night, One I sprayed 150, And melted the # 2 plug again....
Is this a lack of fuel or too much timing?
I have the timing retarded 2-3 degrees from stock, And use 109 Unleaded race gas...
It just doesnt add up.....
Joseph
Joseph
Re: Melting Plugs?
Well, Heres the good part....Its a stand alone fuel system....
Im worried about losing fuel pressure in the top of the gears, I notice voltage drop on my guage cluster volt guage, And the pump is just hooked up through a switch and relay.....
Why only those cylinders though?
Thanks for the replies
Joseph
Joseph
Re: Melting Plugs?
What plugs are you using? Single or dual nozzle or DP?
Matt
Matt
Joseph
Joseph
Re: Melting Plugs?
I also use the delco plugs and have never had issues spraying a 150 shot. Sounds lean to me also. What do the unburned plugs look like color wise? Are they white, light tan or very dark or black?
Ken R.
Ken R.
Re: Melting Plugs?
Originally Posted by sprayedtransam
He doesn't even have the car anymore
, I doubt it if he has any pics of the plugs though...
, I doubt it if he has any pics of the plugs though...Dave
