master arm switch
Old Apr 11, 2004 | 11:53 AM
blazzinbird's Avatar
master arm switch
where does everyone have theres mounted?
i am thinking of mounting mine where the traction controll switch was on the center console
Old Apr 11, 2004 | 12:16 PM
97SS0594's Avatar
camaro's is on the convertable top switch pannel, and the firebird it on the door to the ash tray
Old Apr 11, 2004 | 12:19 PM
on my 96 t/a it is behind the shifter, i dont want it on the ashtrey
Old Apr 12, 2004 | 10:34 AM
Separate panel, mounted in door pocket, with purge, arm, heater and remote open/close.
http://cjcfo.fbody.com/members/injun.../DCP03653a.jpg
Old Apr 13, 2004 | 05:29 AM
MILESF's Avatar
Talking
Mounted mine on the center console behind the shifter.
See my sig..........
Old Apr 13, 2004 | 09:04 AM
JJJ93z's Avatar
same here.
Old Apr 13, 2004 | 09:35 AM
WS Sick's Avatar
I like Injuneers mounting, can easily blend in if you use dark ABS plastice for the construction.
Old Apr 14, 2004 | 12:37 PM
Or just spray the aluminum with interior vinyl paint, just like the paint I used on the A-pillar and the radio blanking plate....
http://cjcfo.fbody.com/members/injun.../DCP03652a.jpg
Old Apr 14, 2004 | 03:11 PM
12Second3rdgen's Avatar
I am not a big fan of the hidden switches. I have a 3rd gen Camaro, and it is mounted right beneath the headlight switch. If for some reason a solenoid hangs, my wot switch sticks (really unlikely) or say I were to have a fire, I don't want to have to shut my system off with a hidden switch.
I have my system wired so that 1 covered toggle turns on two relays, one for the nitrous and one for the fuel pump on the nitrous side. If anything happens, I can shut my entire system off, pump, solenoids and all with one swipe at the toggle cover . Its just my opinion, but if you have a quality nitrous fire like the one at my track earlier last year and your cab fills up with smoke, I wouldnt want to be trying to find my ash tray or secret compartment.
Jlo
Jul 29, 2015 03:52 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
94Form
Jul 17, 2015 10:56 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
