LT1 Ignition w/spray
Old Dec 23, 2003 | 09:54 PM
wannabeZo6's Avatar
aight, im planning on running a 75-100 shot on my Z, just heads/cam setup....beside plugs, fpss, window, purge, blanket....ignition is wut is stumping me.....was wondering if anyone was runnign a MSD digital 6, and how it works.......also do you guys think i need to upgrade the fuel pump on a 100 shot (wet) with 36lb injectors....also wut upgrades does the digital 6 offer as apposed to a 6AL w/rev limiter.....thanks in advance
Old Dec 23, 2003 | 10:41 PM
Wild1's Avatar
NX Maximizer handles the questions you are seeking for safety and performance. A fuel pump is always a good idea with any boost application... try Racetronix (board sponser).
I run a Jacob Electronics with a rev limiter. Any ignition cut is better than a fuel cut. You should have your computer upgraded to raise or extend the factory rev limiter so that the ignition rev limiter has system authority.
On a wet kit, you may not need to upgrade your injectors but it is never a bad idea anyways... again, reprogram your computer with any injector change.
Dry kit, definately upgrade the injectors.
Old Dec 23, 2003 | 11:12 PM
wannabeZo6's Avatar
ya, already have custom tunning and injectors......
Old Dec 24, 2003 | 01:19 AM
Wild1's Avatar
I guess I misread the post, I thought you were adding a question about injectors. You're doing the right thing planning ahead. Some guys just jump into it.
DirtyDaveW
Dec 1, 2016 05:37 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Ari G
Dec 11, 2014 03:21 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
