Just bought used Kit got ???'s
I just bought a 150 wet shot compucar kit off the board. Parts included were Bottle,Hose to solenoid, Fuel solenoid + Hose, N2O solenoid + Hose, Bottle Brackets, And a LT1 plate. The parts I need are :
arm switch
push button
Cable bracket extension
Retard box for my HI-6S
Is there anything else that I am missing that I need to know about?
I checked my fuel pressure and it stays at a constant 39 psi is this correct?
I've never used/or been in a car with nitrous before so any help or suggestions is greatly appreciated.
Dan
arm switch
push button
Dan
well the window switch is an opinion correct? i mean you dont need it to run the system. for that matter you dont really need the fpss switch either. if you lose your gas your motor will shut off anyways so it wont really matter. correct me if im wrong
I ordered a MSD window switch and a NX fpss for 141.32 from the local speed shop a minute ago. Did I get hurt on that? I ordered the WOT switch also. Do I still need to incorporate a push button in the system or just a arm switch now? Any help on wiring this thing up would also be greatly appreciated.
Dan
EDIT : 94 droptop I see that you are in mount holly did you go to the dyno day in charlotte?
Dan
no i didnt get to get there (dyno day)mine is pretty much stock right now.im looking for a cheap truck to buy so i can yank my motor out and build my 396.anyways do you know a GOOD dynotuner for lt1's in charlotte?
