Does Nitrous need PCM programming?
Old Mar 3, 2003 | 08:25 PM
96cam4ro's Avatar
I'm wondering if Nitrous needs PCM programming like a heads and Cam combo or can I just go ahead and spray? Also what else do I need (MSD, new injectors, what plugs etc) to compliment it? Thanks.
Old Mar 3, 2003 | 09:12 PM
94z'sson's Avatar
well on my dads 94 z28 which only has bolt ons and a 2800 stall and 373 gears with 275/50/15 BFG drag radials and a MSD 6al and a window switch and a 100hp shot we went 7.46 at 92.02 in the 1/8 mile
Old Mar 4, 2003 | 12:14 PM
LT4ultraZ's Avatar
It wil work without tuning but not at it's optimal. troy
Old Mar 4, 2003 | 03:13 PM
stik6shift93's Avatar
You dont need to tune the pcm for the bottle at all. Though I would get several different size jets and take it to a dyno and experiment with different jet sizes, the jet sized that come with the kit actually put you a little rich. You'll be able to pick some power up by leaning it out a little(running a smaller fuel jet). I wouldn't lean it out anyhigher than 12.5 though, probably 12 to be safe.
Old Mar 4, 2003 | 06:31 PM
4DRSS's Avatar
If you have a wet system and an ignition box with timing retard you don't need to tune the PCM. Just get it on a dyno with a wideband and make sure your air/fuel is good. If you use the timing retard in the box only when spraying you won't lose any power NA like you would by taking timing out all the time.
Quickss96
Jan 29, 2016 05:56 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
whitehooptie
Aug 17, 2015 08:35 AM
whitehooptie
Aug 10, 2015 07:02 AM
