Introducing 860 Performance Products
Old Nov 25, 2007 | 10:15 PM
Nitro Dave's Avatar
Many of you may already be familiar with the 860 name. 860 Performance has been around in the performance industry for years. Nitro Dave’s has carried the 860 Performance Product line for over 6 years. During this six years Nitro Dave’s established a great liking to the 860 products. With this been said it is no surprise that when the opportunity came available Nitro Dave’s purchased 860 performance with out any second thoughts.
860 Performance Products will now be a company owned by Nitro Dave’s along with Nitrous Outlet, Brand X Nitrous, and Flo Supply.
If you are not familiar with the 860 products take time to check them out.
1. Bottle Heater- 860 Performance offer’s one of the best bottle heaters on the market. This billet heater has the bottle bracket integrated in as a all in one unit. This heater comes with a adjustable pressure switch, quick release stainless straps and a hex to wing adapter. No wrench needed to remove the bottle!
2. Hex To wing adapters. We offer these in 4 an, 6 an, and 8 an. Perfect for main feed lines and blow down tubes. No wrenches needed!
3. V Spray Purge- The V spray purge is great for giving the fat dual spray pattern up over the windshield.
4. F-body spare tire area bottle mount. This unit makes for a nice clean mounting point in the spare tire area of your F-body.
5. Carbon Fiber Bottle *****- Replace your current bottle **** with something more stylish.
6. Blow Down Tube- 860 Blow Down Tubes come with a Hex To Wing Adapter so no wrench is needed!
7. The Hot Box- Heat the nitrous in your bottle all the way down to the core. 860 Hot boxes are temperature controlled. These units work just like a Hot Tub. Fill with water set temperature and walk away.
We will be adding custom build intake elbows as well as other custom designed products to the 860 Performance Product line up. 860 performance is currently having a new website built and should be up and running real soon. You can currently find all the 860 products at www.nitrousoutlet.com
Thank you for all your support.
Dave
F'n1996Z28SS
Aug 23, 2023 11:19 PM
May 1, 2015 01:14 PM
Z284ever
15
Jul 31, 2002 02:07 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
