Questions about alternative adapters for CF bottle.
Bought a 15lb cold fusion bottle. I want to use an -8an line for a blow down tube. What adapters are compaitable with this bottle besides CF. Same question for the adapter that converts to -4an for nitrous feed.
you should be able to use 8an fittings to attach to the pipe away fitting.
http://www.nitrousoutlet.com/catalog...roduct_id=2550
Cold Fusion uses a 660 valve so these will work...
http://www.nitrousoutlet.com/catalog...roduct_id=1965
Hurin
Dec 13, 2014 07:38 PM
