Ignition upgrade a necessity?
Originally posted by George Debski
Joe,
New pump, new ignition. Gotta have!! Also get rid of the stock rev limit in the PCM if you don't want to blow your motor.
Joe,
KASR
Move the stock rev limit on the PCM to around 7500, and use the rev limiter on the aftermarket ignition. The stock limiter shuts off fuel, not a good thing on the juice, while aftermarket units use spark shutoff.
If your bouncing off the rev limit now, it probably means your clutches are going, if not already gone.
