If I put 300 jets on a stock car.....
Old May 27, 2003 | 10:21 PM
Xride's Avatar
If I put 300 hp jets on my stock engine what would happen?
Old May 27, 2003 | 11:22 PM
Camaro_Guru16NY's Avatar
it would go really fast for a few seconds then go booom.
lol,
Later,
-JOhn
Old May 27, 2003 | 11:31 PM
Xride's Avatar
lol,
Later,
-JOhn
haha, in the boom what would break? or would it jsut make so much heat that it would burn my pistons to the cylinder walls type boom?
Old May 28, 2003 | 02:48 AM
Secret Formula's Avatar
Got crank?
Old May 28, 2003 | 06:08 AM
RacinLT1's Avatar
if you are lucky,it will blow the spark out or melt the tips off the plugs.
Worst case you could crack a few pistons,bend/break rods,hurt the crank,window the block.
why would you even think about trying to run that much on a stock car? hate the car that much?
Old May 28, 2003 | 07:01 AM
Xride's Avatar
I wouldnt run it, just knew that it was bad to run that much, but never knew what would actually happen, jsut knew it would go boom.
Old May 28, 2003 | 07:43 AM
Derrick Redd's Avatar
Old May 28, 2003 | 08:21 AM
GhostZ's Avatar
I think you should do it, get a video of it and post it up here for everyone else to see the next time someone has a question about a 300 shot on a stock car
Old May 28, 2003 | 01:09 PM
JSK333's Avatar
FWIW, there is an F-Body mechanic local to me who has been running a 275HP NX shot on his '88 GTA with a stock 4-bolt LT1 (from a Corvette) for a couple years with no explosions. His best run was a 11.0x @ 121 I think.
Old May 28, 2003 | 07:13 PM
Xride's Avatar
hmm would my engine be in its prime for a stroker kit if I did that? how much would someone/s pay to see that?
Old May 28, 2003 | 10:16 PM
RacinLT1's Avatar
i wouldnt pay a penney to see it,but i'd be curious to see what happens at the end.
Old May 29, 2003 | 08:39 AM
4DRSS's Avatar
I know people that have sprayed a 300 shot on a stock LS1, it help up fine. In fact it went 10's with a 300 shot and exhaust
I think you can get away with a 300 shot for a while, provided it was tuned correctly.
Old May 29, 2003 | 06:42 PM
funina91ss's Avatar
get more fuel and a good tune it could happen just hope it never misses a beat.
Old May 30, 2003 | 01:28 AM
11 sec gta's Avatar
Get a nice progressive controller and a bad *** fuel setup, and you'll be fine. Just don't live on the kit.
Old May 30, 2003 | 01:16 PM
Chrisbequick's Avatar
A guy at NX was safely running a 250 shot for quite a while on his stock LT1 short block with a custom built direct port system.
-Chris
