I can't feel the nitrous?
Old Apr 27, 2004 | 11:30 PM
bunker's Avatar
I sprayed a 75HP shot & used nozzles 41/24 to attain it, well I baught the kit used & the bottle had something in it, with heater on I can get it to 950psi or so, but when I spray it I can't feel a thing, could it be that even if I"m getting that nitrous pressure that maybe its just air pressure left & not nitrous? I don't know how this works, but when I spray it it doesn't seem that cold, could it be that you can have pressure but no nitrous inside?
This is an NX kit, & it does spray, I tried to engage it while the car is off.
Matt.
Old Apr 28, 2004 | 05:34 AM
RacinLT1's Avatar
sounds like you need to fill the bottle and try again. just crack open the valve and completely empty it,then get a fresh fill.
the last roughly 2-3lbs in each bottle isnt gonna do much at all for performance.
Old Apr 28, 2004 | 04:38 PM
JodyJ's Avatar
Are you running a FPSS?
Jody J.
Old Apr 30, 2004 | 07:13 AM
Demon SS's Avatar
if you are not getting a cold white vapor when you engage the system or open the bottle then all you are getting is air(mostly). the heater will heat the air in the bottle enough to get the 950psi on the gauge. I believe thatthe bottle is empty as has been said.
WobblySausage
Oct 7, 2015 10:09 AM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
95blkss
Sep 22, 2015 03:18 PM
damnyankee36
Sep 9, 2015 07:06 PM
