How long will a 5# last??
Old Dec 17, 2004 | 02:00 PM
"White Knight"'s Avatar
I was wondering how long will a 5# bottle last?? How long will a 10# bottle last. I am thinking if i have a hard time fitting the 10 in the spare tire compartment neatly, without modifying, that i'll just go with a 5lb. But i would like to know how long each will last.
Old Dec 17, 2004 | 02:23 PM
95_LT1_6SPD's Avatar
Re: How long will a 5# last??
I read somewhere a 10lb bottle will last 3 minutes on a 50 shot. You should be able to fit a 10lb bottle into the spare tire well fairly easily.
Old Dec 17, 2004 | 02:25 PM
EFI67's Avatar
I typically get 3 consistent 150hp passes (12 sec each, +-.1) and the 4th falls off pretty bad on a 10lb bottle.
So a 5lb bottle may last two solid passes at that level. If you are only spraying 100hp, obviously it would live longer.
I tried a 15 pounder one weekend and got 4 good passes with the 5th falling off .25sec (not that it pertains to your question).
Old Dec 17, 2004 | 05:52 PM
rskrause's Avatar
Moderator
General rule: 10sec/lb/75hp is pretty close. Of course, you can't empty the bottle completely. So, ~4 10sec. runs/10lb bottle at the 150hp level.
Rich
Old Dec 17, 2004 | 08:01 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
i have done 3 solid passes at 125 hp level, with some to spare.
although if i dial it up, i can get only one good pass, and then i have to grab a fresh bottle, lmao!!!!
Old Dec 17, 2004 | 08:15 PM
So i guess i won't go below a 10lb then
Old Dec 17, 2004 | 09:19 PM
sprayedtransam's Avatar
You can definately fit a 10# in the spare tire well, I did with my spare tire still in there. Of course I used an older NOS brand bottle, which is longer and skinnier than most newer ones...
Old Dec 18, 2004 | 12:55 AM
taner's Avatar
10 lb fits fine in spare tire area
Old Dec 18, 2004 | 06:54 PM
How do you guys have them mounted? Straight up or at an angle?
Old Dec 18, 2004 | 07:33 PM
MLBurns's Avatar
10 lb will fit at a slight angle in the spare compartment. I get two passes from 10 lb bottle, 5 lb would be frustrating.
Old Dec 18, 2004 | 09:11 PM
rskrause's Avatar
Moderator
What is your ET and how much N2O do you run? That sems like you must be running too high a nitrous/fuel ratio or that you are running a huge (300+hp) shot. Just curious.
Rich
Old Dec 18, 2004 | 10:35 PM
25THRSS's Avatar
I agree, on a 150 shot, you should be using about 0.15 pounds of nitrous per second. You should be getting atleast 5 runs per bottle.
Old Dec 19, 2004 | 05:10 PM
I thought it had to be at a certian angle?
Old Dec 24, 2004 | 07:39 PM
MLBurns's Avatar
Rich
300 shot 11.23 at 125 mph.
Old Dec 24, 2004 | 11:14 PM
rskrause's Avatar
Moderator
So two passes is right on the estimate. ~75hp/10sec for 1lb at the 100hp level = ~4.5lbs for 11sec @ 300hp. IOW, two passes on a 10lb bottle.
Rich
Dark Zeiro
Jul 19, 2015 08:25 AM
Fastbird93
Jul 11, 2015 04:37 PM
cmsmith
Jul 10, 2015 07:19 PM
Boss002
Jul 9, 2015 03:33 PM
Slayer
Jul 4, 2015 03:06 PM
