How long will a 5# last??
I was wondering how long will a 5# bottle last?? How long will a 10# bottle last. I am thinking if i have a hard time fitting the 10 in the spare tire compartment neatly, without modifying, that i'll just go with a 5lb. But i would like to know how long each will last.
Re: How long will a 5# last??
I typically get 3 consistent 150hp passes (12 sec each, +-.1) and the 4th falls off pretty bad on a 10lb bottle.
So a 5lb bottle may last two solid passes at that level. If you are only spraying 100hp, obviously it would live longer.
I tried a 15 pounder one weekend and got 4 good passes with the 5th falling off .25sec (not that it pertains to your question).
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
although if i dial it up, i can get only one good pass, and then i have to grab a fresh bottle, lmao!!!!
You can definately fit a 10# in the spare tire well, I did with my spare tire still in there. Of course I used an older NOS brand bottle, which is longer and skinnier than most newer ones...
Originally Posted by MLBurns
10 lb will fit at a slight angle in the spare compartment. I get two passes from 10 lb bottle, 5 lb would be frustrating.
Rich
Originally Posted by rskrause
What is your ET and how much N2O do you run? That sems like you must be running too high a nitrous/fuel ratio or that you are running a huge (300+hp) shot. Just curious.
Rich
Rich
300 shot 11.23 at 125 mph.
Rich
cmsmith
Jul 10, 2015 07:19 PM
