How big of a shot are you guys running through the TB?
Old 09-14-2006, 05:14 PM
2000GTP's Avatar
I have a dual nozzle wet kit that is adjustable up to a 300 shot. However, I have heard that it is not advisable to spray over a 200 shot through the throttle body because of distribution problems. Is there anyone who has gone over a 200 shot? If I could get a 250 shot out of mine, I would be happy, but if not, I guess I'm stuck with only the direct port option then??
2000GTP is offline
Old 09-18-2006, 06:55 PM
mrr23's Avatar
Re: How big of a shot are you guys running through the TB?
http://www.stealthram.com/2000formulanitrous.htm
mrr23 is offline
Old 09-18-2006, 07:25 PM
2000GTP's Avatar
I decided I will just keep it jetted at a 200 shot once I get the motor rebuilt and to that point. Thats a very nice setup and great pictures... its giving me some new ideas on how to reroute a couple of things.
2000GTP is offline
Old 09-18-2006, 08:47 PM
Moderator
rskrause's Avatar
I've run up to 250 with no issues.
Rich
rskrause is offline
Old 09-19-2006, 01:09 PM
2000GTP's Avatar
Rich
What kind of kit were/are running? Did you have to take any additional precautions?
2000GTP is offline
Old 09-20-2006, 09:23 PM
n20ta2's Avatar
I have run a 300 shot through the TB and it worked fine,no issues with lean cylinders as far as I could tell.Motor ran that way for maybe 20 passes before I decided on a different combo
n20ta2 is offline
Old 09-22-2006, 03:21 PM
2000GTP's Avatar
Thanks for the input, maybe I will take a gamble with a 250 shot afterall once the bottom end gets rebuilt. I will just make sure to take logs during each run.
2000GTP is offline
Old 09-29-2006, 09:12 AM
Moderator
rskrause's Avatar
I made it up from NX components. I am using two nozzles in the intake at ~3 and 9 o'clock a few inches in front of the TB. I doubt that the distribution is perfect, but never had any issues related to the nitrous. A single nozzle with the two bbl. TB just didn't look right to me.
Rich
rskrause is offline
Old 09-30-2006, 01:13 PM
n20ta2's Avatar
ditto on my old combo as well
n20ta2 is offline
89 iroc zl1
3rd Gen / L98 Engine Tech
01-14-2015 02:18 AM
FIREBIRDMARK1
01-07-2015 03:36 PM
sleeperZ96BT
09-05-2002 05:45 PM
sleeperZ96BT
08-16-2002 02:24 AM
Red97LT1
08-07-2002 05:45 PM
Quick Reply: How big of a shot are you guys running through the TB?
