How to active n2o in second
Old Apr 28, 2003 | 10:42 AM
95greendragon's Avatar
Anybody have any good ideas on how to active n2o when I hit second gear WITHOUT spending like 200 dollars? I was thinking maybe some kind of swith that gets tripped by the shifter shaft.
Old Apr 28, 2003 | 12:18 PM
Jon in SD 97Z's Avatar
Just use a trigger in your hand either on a cord or on the shifter like I and many others do.
Here's mine
Old Apr 28, 2003 | 12:20 PM
You are shifting and hitting the button every time??!?
Old Apr 29, 2003 | 07:53 PM
Yup, and walking and chewing gum at the same time too
Whats so suprising about that? If you mean holding the button through the shifts, then no I release between shifts.
Old Apr 29, 2003 | 09:45 PM
number77's Avatar
what if you could mount someting under the pedal so that every time you hit WOT the nitrous would start and you could have a seperate switch to activate it so you don't spray all the time
or you could set up a piece of bent flexible metal to put in the shifter so that when 2nd hits it just completes the circut
Old Apr 29, 2003 | 10:11 PM
stik6shift00's Avatar
alot of kits only activate at WOT...like nx/ and tnt...just dont go full throttle in first and most of second...you will spin anyways if you do...
Old Apr 30, 2003 | 03:31 PM
OutKast's Avatar
Just a suggestion for you. I had my button on the shifter and couldn't shift nearly as well. Bad coordination most likely Moved it over so that I can hang the button on the lever that you use to adjust the column and when it comes time to spray I can hold it with my left hand. I dropped a couple tenths by moving it to where I wasn't struggling with it.
Old Apr 30, 2003 | 06:10 PM
BILLJ's Avatar
As far as the nearly $200 for the setup I've been working on, I've been digging hard, cutting out middle men, and changing the desing a little to shave the cost. I have gotten it down to $167.95. figure about 5 for shipping and no tax if u dont live in IN. I could try and shave another 5 - 7 off but that would take another month and a half to find a way to cut it. Plus your looking at 100 rpm adjustments, not 200, and no pill kits you have to buy, u can turn the lockout off/on, and run second stages with it. I've delt with shifter postion sensors(mechanical and optical) and have had nothin but problems and headaches so thats why I built my setup and put it on my vette. No troubles since and figured others would like it too.
generaldave
Sep 25, 2015 06:48 PM
Aug 7, 2015 08:52 AM
tbyrne
Aug 16, 2002 01:12 PM
Kev@ramchargers
Aug 15, 2002 04:10 PM
rje
N2O Tech
Jun 18, 2002 06:44 PM
