N2O activation ?
Old Jun 17, 2002 | 07:25 PM
rje's Avatar
rje
Post N2O activation ?
I am planning on spraying a 125 shot this weekend and was wondering if the way I have things setup is safe? I only us a micro switch for WOT activation and want to know if the system will be activated to soon like this. I've sprayed a 75 shot with no problem, but what about the 125 ? I ususally stall against he converter to about 2200 rpms then when the light goes on I go to the floor. I figured that with my 4000 converter I should have plenty of rpm before the n2o comes on, but what do you guys think?
Randy
94Z 355 cid Hughes performance TH350 with 4000 TC, ported and polished 2.00, 1.57 valve heads, ported intake, 52mm TB, Bullet custom grind cam, Comp cams R series lifters, Hooker LT's, custom dual exh. with dynomax bullet mufflers,CSI elec. WP,MSD Digital 6+ ign,Autogage 5" monster tach with shiftlite,AC delete pulley, CC pro mag 1.6 rockers, Forged Ross pistons, 11:1 cr,B&M Pro stick shifter, eagle rods, polished stock crank,balanced rotating assembly , 24lb SVO injectors,Nitrousworks wet kit, AFPR, pcmforless custom program, alston SFCs, boxed LCAs with relocation brackets, tubular panhard rod,chassis engineering 8-point rollbar with 5-point harness, BMR Trac Pak, moser 12 bolt with 4.10's,1LE DS,Hurst line lock, eibach drag launch kit and airbag, HAL 12 way adj struts,CE 3-way adj. shocks, 15x3.5 front and 15x8 rear Weld Draglites with 27x11.5x15 Hossier QTP's. 1.607 60ft 7.62 @ 89.62 mph 1/8 12.02 @ 110.48 mph on motor.
1.57 60ft 7.31 @ 94.2 mph 11.51 @ 115.47 mph (75 shot) Shooting for 10's
In memory of the greatest
#3 Dale Earnhardt The Intimidator
Old Jun 17, 2002 | 08:11 PM
94Z28DOJ's Avatar
Post
It shouldn't come on, but you can get a window switch just in case. Hope you got some good tires because 125 lot funner then 75.
Old Jun 17, 2002 | 10:43 PM
rje's Avatar
rje
Post
What I meant was that I didn't want the n2o to come before I got the necessary rpms so as not to bend a rod. As for tire, my 27x11.5x15 hossier qtp's hook quite well tot he tune of 1.59 on the motor.
Randy
Old Jun 17, 2002 | 11:27 PM
Z28ROC's Avatar
Post
I used to spray without a window switch on a stalled LT1. But it only takes one low RPM activation to cause a big boom! I personally would never spray without a window switch.
Mario,
White 94 Z28
Yeah I got a few mods
Video
Old Jun 18, 2002 | 06:44 PM
gb95zconv's Avatar
Post
If the engine should happen to stumble for some reason you could have a big problem. Thats less likely with an auto but it still is a real possiblity. Get a window switch and no worries.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
generaldave
Sep 25, 2015 06:48 PM
Aug 7, 2015 08:52 AM
cristian1311
N2O Tech
Jun 5, 2015 05:08 PM
tbyrne
Aug 16, 2002 01:12 PM
Kev@ramchargers
Aug 15, 2002 04:10 PM
