Help With N2o Lines!!!!!
Re: Help With N2o Lines!!!!!
FYI
I just caught this thread and about 6 months ago installed a NOS Noszle system on my LT1. I mounted the solenoids about 6-8 away from the intake manifold and ran nylon lines to the noszles. I agree that you should not consider using nylon lines for a single shot system too much pressure but with a direct port the pressure will drop after the solenoid when you branch it off. The nylon line was WAY overprice from every NOS vendor so I did some searching and found that Newage Industries make the line for NOS and relables it for them. The line is Nylotube 12 I believe my has a working PSI of 1000 at 70F. This is the link. I've had no problems so far.
http://www.newageindustries.com/nylon12.asp
BTW, I picked up a 500/1000ft roll for like $60......
Jason
Jason
