Help with ignition box settings
Aight, my mallory is on the way. Had a few questions. What's the stock rev limiter set at? What're '94 Z shift points set at? Should I set the mallory rev limiter 100 RPM below the PCMs then the window switch another 100 below that? I shouldn't put mallory's limiter right on with the PCMs should I? Basically what I'm asking is what the window switch should shut off at and where mallory's limiter should go.
