Fuel system for 200 direct port
Old May 16, 2005 | 02:58 PM
RacerTim's Avatar
Got kit in today, NOS Sportsman. I dont really want to go with a seperate fuel system at this point either. Would it be safe to fun the fuel for the system off the test valve? Or should I look into taking it somewhere to weld a fitting onto the rails?
Old May 16, 2005 | 05:21 PM
LameRandomName's Avatar
Re: Fuel system for 200 direct port
Do yourself a favor and use the seperate fuel system. You can get a small fuel cell at summit, jegs or just about any speed shop. (They probably all come from the same place.)
Old May 16, 2005 | 06:42 PM
RacerTim's Avatar
I'm planning on going up to a 250 shot eventually, so I know thats the smart thing to do in the long run. But is using that valve, that bad? Would having the fuel rails tapped and running a seperate line from them to the noids be almost just as well?
Old May 16, 2005 | 10:07 PM
Nitro Dave's Avatar
The problem is that you are going to need a big fuel pump to support a direct port and motor.More than a intank standard pump will support.You can use our stand alone system and have all the fuel you could ever need.Here is a link.
http://www.nitrousoutlet.com/outlet/...section_id=122
Dave
DirtyDaveW
Dec 1, 2016 05:37 PM
CARiD
Jan 27, 2015 06:27 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Jul 4, 2005 05:00 PM
