fuel pump question
fuel pump question
If I run a walboro 255lph pump will I absolutely need a fuel pressure regulator?
btw car is a bolt only car and plan on running a 150hp shot in the spring.
Are you asking "do I need to keep the fuel pressure regulator in my system with the Walbro pump"? = YES.
Or are you asking, "do I need an upgraded or adjustable fuel pressure regulator in my system with the Walbro pump"? = NO
How you configure the fuel system will depend on whether you use a wet or a dry shot.
sorry about that my bad..I meant a upgraded FPR
I will be running a wet shot,
will I need the FPR to control the fuel going to the N20 system or will the jets do control the flow?
Thanks.
Thanks.
