Fpss differences
Old Feb 11, 2005 | 09:26 PM
MarkyMark's Avatar
Fpss differences
Is there any difference between different manufacturers of Fuel pressure safety switches? Or is the fpss so simple that all manufacturers are basically the same? Reason I ask is because I have a brand new NOS fpss and I wanna use it with an NX system.
Old Feb 12, 2005 | 11:19 AM
MEAN_SBC's Avatar
Re: Fpss differences
The NOS fpss will be fine, as long as it is designed for your application (efi, or carb). They all function the same way... If your fuel pressure drops below a certain point, they break connection.... So it will be fine..
Old Feb 12, 2005 | 06:13 PM
Mtrhds94Z's Avatar
While they do all work basically the same way, they can be rated for different pressures.. or be 'normally open'or 'normally closed' switches..
I'd check [via mfgr and part#] to be sure.. or test it to be sure..
Old Feb 12, 2005 | 09:58 PM
MarkyMark's Avatar
On the back of the packaging it says......50 psi EFI pressure switch. Does that sound right, or does that not mean anything?
Old Feb 12, 2005 | 11:49 PM
That sounds correct. I bought an FPSS from NOS and it was rated 50psi, but could be adjusted to higher or lower pressures using the screw under the rubber plug on top of the switch. I think it says on the switch itself that it is made by Hobbs, and I think they make most of them. Doesn't matter what system you use it in, its just a switch.
http://content.honeywell.com/sensing...reSwitches.asp
Old Feb 13, 2005 | 04:52 PM
MarkyMark's Avatar
Thanks everyone that really helped. Turns out now though that the NX kit I am probably gonna buy (used) has the NX fpss with it, so I may just sell the NOS one. Thanks again everybody....
Old Feb 13, 2005 | 06:09 PM
25THRSS's Avatar
What psi range is the NOS fpss vs the NX fpss?
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
