fpss adjusting ?'s
Old Jul 13, 2002 | 02:11 PM
kirschman's Avatar
Post fpss adjusting ?'s
Having a few probs. with the juice here and I think its the fpss. Its set from factory at 35, I dont have access to a pressure gage and was curious if somone can give me a "ballpark" figure on how much it will turn the pressure down with like, say, one full counterclockwise turn. Bout half scared to bypass it altogether. What would be to low of a pressure setting?
96Z M6, 12 bolt Moser(3.73),NX wet kit(all the goodies),MSD 6AL,tayor spiro-pro,NGK tr-6,Star stage 2 kevlar,pcmforless programing, SLP CAI,!maf,LT4 NM,Flowmaster,Hurst roll control,BFG DR's,Pro 5.0,BMR DS loop...
13.52-103.8 mph
60ft. 1.99
no n2o times yet
Old Jul 13, 2002 | 07:44 PM
gb95zconv's Avatar
Post
I wouldnt want to go lower than the 35 setting.....get you a gauge and check it, it may be faulty.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Jul 13, 2002 | 07:55 PM
Post
I wouldn't necessarily trust the "set from the factory" number. I put the FPSS in a "tee" on the line from my air compressor, and adjust the air pressure with the regulator, then check the FPSS with an ohmeter to make sure it is opening and closing at the pressure I want.
I also wouldn't go below 35psi if your fuel jetting is based on stock fuel pressure of 43.5psi. You should not be much below that at WOT, or you have a problem.
Another thought would be to wire a pilot light or LED across the nitrous solenoid, so you have an indication in the cockpit that the solenoid is actuated, and will see the light go out if the FPSS is causing it to shut down.
Fred
94 Formula A3: 381/TH400/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Old Jul 13, 2002 | 10:38 PM
kirschman's Avatar
Post
Thanks for the help guys!
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
