F.A.S.T ECU and NOS, need tuning help...Highly Technical!!!!
Old Jul 16, 2002 | 07:25 PM
james007moore's Avatar
Post F.A.S.T ECU and NOS, need tuning help...Highly Technical!!!!
I can't seem to get anyone to answer this question!!!!!!!!!
I have a supercharged LT1 camaro, with the new HOLLEY 58mm NOS TBI unit. I plan on setting my power at 100hp for the NOS. Holley says for me to use a 47 jet for the NOS for 100hp. My question is how much FUEL do i tell the ECU to add????????
Is there some kind of formula used to determine the amount???? I know NOS is tricky, so i am not looking for exact numbers, i just want a safe starting point!!! I can handle it from there, I think.
thanks,
james007
Old Jul 16, 2002 | 08:14 PM
KTamez's Avatar
Post
Replied in Advanced Tech
Old Jul 17, 2002 | 09:01 AM
stockLT1's Avatar
Thumbs up
Call ED Wright
918 446 3019
Good luck,
-Scooba
'93 Z/28 M6 3.73's_6point cage_orange with yellow pearl_RK sport GFX_SS hood_RK sport hi rise wing_clear corners_billet grille_ported heads/intake_5 angle perf. valve job_97'LT4 383 by SELF RACING_CALLIES stealth crank_OLIVER six inch rods_J.E.forged dished pistons_10:1 compression
OLIVER splayed mains_custom grind cc306_LINE BORED_BALANCED AND BLUEPRINTED_FASTCHIPS custom chip and ED Wright DYNO tune_EGR bypass_home made SFC's_home made short throw_home made LCA's_home made CAI
Eibach Pro kit_ET Streets_Hooker ceramicoated LT's W/true duals and "H" pipe_Taylor Spriro wires_Autolite 104's_Aeromotive adjustable FPR_30# injectors,58mm TB, 1.6 comp pro magnum RR's
N.O.S. wet system 300 shot
_ ______________________ _
PAXTON S591 w/12 LB pulley in the works (need to custom fab some brackets)
Aug 24, 2015 06:41 AM
Shookiez28
Jul 23, 2015 01:55 PM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
colts0455
Jul 20, 2015 09:52 AM
