Electric WOT switch
Old Mar 17, 2005 | 11:55 PM
captaindbol's Avatar
Electric WOT switch
What wire do you tap into to get your WOT signal voltage? I'm using the dynotune switch. Should be the same as ZEX and NX. And yes, I used the search button.
Old Mar 18, 2005 | 09:18 AM
BlownF1's Avatar
Re: Electric WOT switch
If you've got a schematic, it's the TPS sensor line at the PCM. I don't have a wire listing handy to give you the exact wire location and the f-body install guides don't seem to be working at the moment. There might be something in there...I couldn't find anything with a search either. From memory, I want to say it's the clear connector (there are 4 colored connectors on the PCM), wire # 22...but VERIFY that first!
Old Mar 18, 2005 | 03:56 PM
TransAmGT's Avatar
I think it's the blue one coming off the tps on the throttle. Not 100% sure though.
Old Mar 18, 2005 | 03:59 PM
BlownF1's Avatar
You can pick it up at either the TPS sensor or the PCM...same wire. It's easy to check, just hook up a voltmeter and and move the throttle. It should vary linearly from about .5vdc to roughly 4.5vdc with the key on. The other 2 wires are 5V and ground.
I preferred to get it at the PCM and ran it inside so all the electronics was under the dash and protected.
Old Mar 18, 2005 | 04:02 PM
DrewHMS97SS's Avatar
i second the blue wire
Old Mar 19, 2005 | 07:31 PM
Checked out with a voltmeter today, for anyone else searching this topic, its the blue wire. Thanks guys.
Quickss96
Jan 29, 2016 05:56 PM
Henson071
Sep 18, 2015 04:01 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
tdigger9899
Sep 7, 2015 10:56 AM
