Effects of colder plug on motor when not sprayin?
am I going to notice any difference in my engines performance using a colder plug when I'm just running on motor....question just popped in my head...
You'll be fine in the NA application. Being a copper conductor plug, they will require sooner interval changes. I have read a couple of publications where one step colder,TR-6 plugs were swapped into a NA motor and a few extra ponies resulted on the dyno.
I would doubt that you would gain hp going to a colder plug. I run NGK br7ef plugs in my car. Car seems to run exactly the same. Only problem you may run it to is if you start the car in 30deg or below weather. It make take 10-20sec for all of the plugs to warm up.
I don't run my nitrous plugs on the street, unless I'm being lazy. They come out black, and I don't like it. Definitely, in the summer only. The cold winter starts would kill 'em.
I run TR6s with the 180 shot or so. I'm not sure on a 300 shot. I run an all stock Lt1 motor, so I have to be careful on shot size. You'll have to do a search.
Ditto with Andy... I can't run my nitrous plugs on the street. They would be fouled after 10-15 minutes of low load driving. I run Champion S57YC with the 300-shot, get by with Autolite 103's with a 125-shot, and 103's or 104's on the street. I think that's what they are.... I haven't actually raced or driven the car in so long I forget whats in it
I run the Autolite AR racing plugs in mine 4 ranges colder then stock and run them on the street also. I like to keep them in there cause i'm boosted also and then spray it at the track. I haven't had a problem with fouling them. I'm sure you won't need to go 4 ranges down, but probably at least 2. The other guys are right though, go too cold and the'll foul.
Ken R.
Ken R.
Henson071
May 4, 2015 12:23 PM
armedtrigger
Feb 24, 2015 08:30 PM
Jan 23, 2015 01:13 PM
