Easiest way to get window switch/progressive/timing retard
Old Oct 5, 2005 | 11:41 AM
jsetzer's Avatar
What is the easiest way to get all this done?
I don't want to run 3 boxes under the hood, I see Harris has the Edge, and it has an output for timing retard, but I would assume that is just like a relay to go out to an msd box or something. Anything out there that can do all of it without costing a fortune?
I sprayed before on my stock setup / stock tune and only had an rpm switch cut it off before the redline. Wanting to be a little safer now that I have a cam and lots more tuning done.
Old Oct 5, 2005 | 11:50 AM
LWillmann's Avatar
Re: Easiest way to get window switch/progressive/timing retard
I bought a Mallory 685 box for my car. It has two rev limiters, a window switch, a timing retard for nitrous, and for boose, a start retard, and a tach output.
It's running really well in my car.
Old Oct 5, 2005 | 12:58 PM
HarrisSpeedWorks's Avatar
You are correct; you will need an ignition system that can be triggered to do the timing retard. As far as I know there is no "all in one" box currently available. I see you having to run 2 boxes, one being a progressive controller and the other being an aftermarket ignition that will allow you to pull timing.
Matt
Old Oct 6, 2005 | 11:16 AM
InsuranceGuy's Avatar
JACOB 's Mastermind will do everything except cut the nitrous
off at a predetermined RPM. It has the retard, start nitrous
and progressive.
Emil:93Z,Vortech,NOS,water/methanol
Old Oct 6, 2005 | 11:23 AM
Nitro Dave's Avatar
I do not know much about the jacobs.Do you have a after market ignition system on the car now.You will need to run a seperate box for timming but I would suggest the new 200 progressive from NX it will do everything else and can not be beat as far as quality.....
Dave
Old Oct 6, 2005 | 01:44 PM
You'll still need an aftermarket ignition system to use that feature. Here's a link to their manual:
http://go.mrgasket.com/pdf/NMM_PT1.pdf
Matt
and progressive.
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
z28cam1993
Sep 9, 2015 04:08 AM
Jul 10, 2015 02:23 PM
