Different N20 question
Old May 11, 2004 | 10:46 PM
94NDTA's Avatar
My freind was telling me what he knew about N20. He was telling me that N20 can cause warping on parts in the engine from the sudden temp drop, then the rise againt from N20. Is this ture, or a common problem at all?
Old May 12, 2004 | 05:20 AM
RacinLT1's Avatar
in my 10+ years of nitrous use,i have never heard that or experienced anything like it.
almost seems like 1 of the misconceptions that people spread when they are scared of nitrous.
in theory it could be true,but i have never experienced anything like it.
Old May 12, 2004 | 10:17 AM
MEAN_SBC's Avatar
Sounds like your friend actually knows nothing about nitrous.....
Old May 12, 2004 | 10:01 PM
BILLJ's Avatar
Go through some post here and read up. You will learn more in 1 hour then what your freind spent his hole life learning about it. If you still have ?'s then just ask.
Old May 14, 2004 | 10:14 AM
MEAN_SBC's Avatar
this is cut/pasted directly from NX's website:
Q. Does nitrous increase cylinder temperatures and combustion chamber pressure?
A. No, cylinder temperatures should stay the same when the correct nitrous air/fuel ratio is used. Yes, increased cylinder pressure equals increased horsepower.
So if everything is tuned right, there shouldn't even be a significant temperature change.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
T/A lt1
Oct 10, 2002 03:14 PM
PhantomTA
Sep 7, 2002 08:44 AM
T/A lt1
Sep 5, 2002 06:53 PM
