Did search..please post 'noid mounting solutions
Old 08-09-2006, 05:37 PM
Soccerbum21's Avatar
Question Did search..please post 'noid mounting solutions
just like title.
everyone's pictures seem to be outdated and not coming up anymore
i have an LT1 and i am looking for a more stable way of mounting my solenoids.
i have 18 inch lines from the solenoids and an 18 inch line from the shrader valve to the fuel 'noid and plenty of slack on the long line.
the nozzle is placed on the bottom of the fernco 3" elbow i just purchased after reading about it and my stock one has gone to crack.
so, the nozzles need to be close enough to go to the underside of the elbow, and i would like to hard mount them somewhere, i have the plates to do this, and they are NX solenoids.
Soccerbum21 is offline
Old 08-09-2006, 05:40 PM
speed_demon24's Avatar
Re: Did search..please post 'noid mounting solutions
At first I mounted mine by bending the mounting tabs 90 degrees, and mouting them ontop of the tb using the top 2 bolts, but I didn't like that, so now I have them mounted on the front 2 fuel rail bolts.
speed_demon24 is offline
Old 08-09-2006, 08:22 PM
camaro81's Avatar
I mounted mine on one of the back fuel rail bolts.
camaro81 is offline
Old 08-12-2006, 12:31 AM
97formulakid's Avatar
I mounted mine on one of the back fuel rail bolts with a custom bracket I made. I would get some pics but I am 6 hours away from home right now.
97formulakid is offline
Old 08-12-2006, 09:51 AM
2000GTP's Avatar
I rigged up some custom brackets as well. I'll try to post some pics. later.
2000GTP is offline
Old 08-12-2006, 12:40 PM
camzaro28's Avatar
same place i have mine. on the front fuel rail bolts.
camzaro28 is offline
Old 08-12-2006, 07:19 PM
Heres a pic if it helps you at all
Old 08-21-2006, 02:54 PM
WhyHelloOfficer's Avatar
Mine are mounted on homemade brackets on the firewall.
WhyHelloOfficer is offline
Old 08-21-2006, 10:31 PM
my94blackz's Avatar
Mine
Guy at atlanta
my94blackz is offline
Old 08-22-2006, 11:22 AM
I can't get a great picture because the strut tower brace is in the way -- but here is mine on the firewall
Old 08-27-2006, 01:10 PM
buzz12586's Avatar
I really like that setup. Its well hidden. Might have to try that when I do my kit.
buzz12586 is offline
Old 08-27-2006, 09:00 PM
Works out pretty well. If you want more pics just shoot me a PM and I can email them to you.
Also if you've got any other questions about the install let me know -- I went through quite a few hoops to get mine running right, but I'll admit the ends definately justify the means.
As far as install help, I'm more than willing to give you advice if needed.
silvermansteve
03-04-2015 05:02 PM
SpeedJunkee
01-27-2015 10:02 PM
Absolute Z28
07-19-2002 02:21 PM
Quick Reply: Did search..please post 'noid mounting solutions
