Delteq and nitrous
Old Jul 6, 2005 | 04:41 PM
Froggy's Avatar
Delteq and nitrous
Okay guys, I've been searching but still can't find what exactly I need to retard the timing for my Delteq. I checked Delteq's website and they say to use the Crane Cams TRC-1, but Crane no longer makes them (at least that's what the guy on the tech line said). I know I can use the MSD DIS-4, but MSD's tech line says that I need 4 coil interface modules. Is that true? I know that some of you out there are using the DIS-4, please chime in and tell me exactly what I need.
Old Jul 6, 2005 | 10:31 PM
ponykillr75's Avatar
Re: Delteq and nitrous
what you were told about the dis 4 and the interface coils is true
i was dreading buying the dis4 and then i found out about the interface coils and decided to go back to the opti
i believe the coils were something like 25-30 bux each
Old Jul 10, 2005 | 03:23 AM
Froggy's Avatar
Thanks for the answer. I don't want to spend anymore money either , but I like the Delteq and want to keep it. Thanks again for the reply.
Thomas S.
Old Jul 13, 2005 | 09:38 AM
gex598's Avatar
I have a delteq and MSD Dis-4, also have nitrous. If your planning you getting a dis-4 make sure you get a new one!!!!! The older models dont have a step retard the made more for boost as timing is pulled from zero to your set about at your rev limiter....ie start retard at 4000rpm rev limited is set to 6500 you pull 6 degrees your not going to get the full 6 degrees of retard till 6500 at 4000 your pulling 0. Also the dis-4 is NOT low rpm friendly most of the features are geared to high reving engines. On a stock short block it wont be of much use because the retard function lowest point is 4000 and the rev limiter starts at 6250. The new units with the rotary dial will control lower rpm and also have a built in step retard.
Jason
Old Aug 14, 2005 | 12:00 PM
ZBLKHELLRZR's Avatar
Where can the DIS-4 the new version be bought at? I'm in the same boat and want to keep the delteq system. Thanks!
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
tommalcolm
Sep 11, 2015 03:39 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
