a couple beginner questions
Old Jan 21, 2007 | 04:16 PM
xdamagedx's Avatar
First: on the spray nozzles, it has fuel and nitrous fittings... this is obviously to mix them, but does fuel also get supplied from the Carb.? Or is your fuel always passing through that nozzle now?
Second: I have an 85z, and I believe it had a Q-jet from the factory (carb was changed before I bought it). I have a stock intake, but I've got a Holley carb. on it. If I were to purchase a nitrous system, what kind of plate would I need? Something Q-jet based, or something Holley based?
Third: Are window switches made for generic distributors? or are they more-so made for computer controlled cars?
Thanks in advance
Old Jan 21, 2007 | 04:54 PM
n2oCamaro's Avatar
1st-The fuel passage in the nozzel is to supply fuel enrichment for the nitrous hit only. The carb will still be supplying fuel.
2nd-Holley based.
3rd-Window switches get their reference from the coil so they will work on almost anything
Old Jan 21, 2007 | 11:14 PM
Ray@NitroDaves's Avatar
Thanks in advance
as stated above the carb will continue to supply fuel for the motor..
which plate you need will depend on whether you have a speadbore or 4150 style intake...not sure what stock configuration is off the top of my head
the window switch will work on your vehicle...you will just pick up tach signal from the coil
Old Jan 23, 2007 | 12:25 PM
xdamagedx's Avatar
"which plate you need will depend on whether you have a speadbore or 4150 style intake...not sure what stock configuration is off the top of my head"
How do I determine that?
Thanks for the reply guys
Old Jan 23, 2007 | 01:12 PM
the easiest way to tell...look at the carb....if the back 2 butterflys are larger than the fron 2 it is a spreadbore (Q-Jet)...if they are all the same size...it is a 4150 (Holley)
Old Jan 24, 2007 | 01:59 AM
xdamagedx's Avatar
well wouldn't that just tell me what kind of carb. i have? I believe (I haven't gotten up close and personal in a few weeks) it's a normal q-jet intake with an adaptor and the Holley on top of that... all that ASSUMED to be true, I could use either type if the nitrous plate is manifold determined...? Or is the nitrous plate carb. specific?
Old Jan 24, 2007 | 09:08 AM
that is the info we needed....in your first post you said "I believe it had a Q-jet from the factory (carb was changed before I bought it). I have a stock intake, but I've got a Holley carb. on it."
If you "know" it is a q-jet manifold you will need a spreadbore plate.
http://www.nitrousoutlet.com/catalog...product_id=384
This is the plate conversion, comes with everything needed to run the plate.
If you already have the jets, gaskets, hardlines etc.....
http://www.nitrousoutlet.com/catalog...product_id=403
this is the plate only...
Old Jan 26, 2007 | 12:54 AM
xdamagedx's Avatar
to figure this out do I need to pull the carb off? or can I open the butterflies and look down in there?
So it IS manifold determined?
Old Jan 26, 2007 | 09:10 AM
yes...the plates are dictated by the manifold design...the mounting flanges have to match
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
Louey
Pacific
Nov 28, 2014 03:46 AM
