Could I use this switch...
Old Oct 10, 2005 | 07:47 AM
Loony's Avatar
On my '97 Z there's a switch that trips with the clutch pedal is released. The pedal basically rests on it while the clutch is engaged. Now, do you guys think it's a good/bad idea to wire that switch, along with a WOT switch, to deactivate the spray when you press the clutch in? That way it shuts off right before the shift...and once you're up a gear and back on the gas. Maybe?
I don't have a kit yet...still waiting for a decent priced one...TIA
Old Oct 10, 2005 | 08:06 AM
BlownF1's Avatar
Re: Could I use this switch...
I wouldn't bother...if you lift off the gas on the shift, it'll do the exact same thing.
Old Oct 10, 2005 | 08:07 AM
LWillmann's Avatar
If you power shift, this might be a good idea as it would keep the nitrous from spraying during the shift. If you speedshift then it probably won't make that big a difference since you're coming off the gas during the shift anyway.
94magh
Aug 19, 2013 10:05 AM
Y2K2Sierra
Oct 27, 2004 04:07 PM
Y2K2Sierra
West South Central
Oct 27, 2004 04:05 PM
Need4Camaro
Aug 30, 2004 12:56 PM
385LT1
Sep 15, 2003 12:03 PM
