car feels a tad faster after n2o use??
Old 09-16-2003, 09:28 PM
TMDZ28's Avatar
am i imagining things?? cause i feel my car runs a little smoother and stronger after n2o use....
any explanation???
TMDZ28 is offline
Old 09-16-2003, 10:11 PM
RacinLT1's Avatar
probably a mind game,BUT if there was carbon buildup the nitrous coulda gotten rid of it and made it run better.
that or you gutted the Cat converter and dont know it yet (if you have 1)
RacinLT1 is offline
Old 09-16-2003, 10:12 PM
samdogmx's Avatar
i had the same feeling after the first time i sprayed my motor.....
i just assumed i had knocked all the carbon loose
samdogmx is offline
Old 09-16-2003, 11:41 PM
TMDZ28's Avatar
i dont have any Cat conv. on my car......i guess it is a mindgame or my engine runs a lil cleaner
TMDZ28 is offline
Old 09-21-2003, 12:37 AM
amean94ta's Avatar
you might have swelled your rings and now have closer tolerences because when you use n20 the added heat in the combustion chamber swells the piston and rings well if your rings where wearing down and not sealing there best the n2o might have fixed it for you (temporaly)because after time the swelling will cause ring wear and might score onto the piston
amean94ta is offline
Old 09-29-2003, 12:06 PM
scans's Avatar
WOW...screw the rebuild...I'm just going to spray the bitch...
JK... Saftey First!
scans is offline
Old 09-29-2003, 02:28 PM
TMDZ28's Avatar
will a messed up ring caused a bad run NA??
cause my NA run is pretty good, have not take my car to the track yet though, but i'll dyno it next month....we'll see what happens
TMDZ28 is offline
Scottylt1
01-08-2015 02:48 PM
ModdedNerd
12-10-2014 08:42 PM
Scottylt1
12-04-2014 12:31 PM
USAirman93
11-24-2014 03:37 PM
Black93lt1
11-21-2014 07:30 PM
Quick Reply: car feels a tad faster after n2o use??
