car feels a tad faster after n2o use??
am i imagining things?? cause i feel my car runs a little smoother and stronger after n2o use....:confused:
any explanation??? |
probably a mind game,BUT if there was carbon buildup the nitrous coulda gotten rid of it and made it run better.
that or you gutted the Cat converter and dont know it yet (if you have 1) |
i had the same feeling after the first time i sprayed my motor.....
i just assumed i had knocked all the carbon loose ;) |
Originally posted by RacinLT1 probably a mind game,BUT if there was carbon buildup the nitrous coulda gotten rid of it and made it run better. that or you gutted the Cat converter and dont know it yet (if you have 1) |
you might have swelled your rings and now have closer tolerences because when you use n20 the added heat in the combustion chamber swells the piston and rings well if your rings where wearing down and not sealing there best the n2o might have fixed it for you (temporaly)because after time the swelling will cause ring wear and might score onto the piston
WOW...screw the rebuild...I'm just going to spray the bitch...:eek:
JK... Saftey First! :D |
Originally posted by amean94ta you might have swelled your rings and now have closer tolerences because when you use n20 the added heat in the combustion chamber swells the piston and rings well if your rings where wearing down and not sealing there best the n2o might have fixed it for you (temporaly)because after time the swelling will cause ring wear and might score onto the piston cause my NA run is pretty good, have not take my car to the track yet though, but i'll dyno it next month....we'll see what happens |
