Car dies after using N2O??!! Help?
Old Apr 12, 2005 | 03:08 PM
Black1995Z's Avatar
Unhappy Car dies after using N2O??!! Help?
I have been using N2O (NX 100 wet shot) for a couple weeks now on a daily basis. This has happened only twice.
First incident: I was in first gear and got on it then I let off and hit the brakes and came to a dead stop. The car just died.
Second incident: Today I was giving a friend a ride with the new setup and a several minutes after I was at a light about to turn left... as soon as I hit the gas lightly the car surged as if it was going to die but just pulled itself up.
My car is bone stock with exhaust and LT4 knock module. New opti, plugs and wires. Whats causing this? Anyone else have a similar experience?
Old Apr 12, 2005 | 08:32 PM
bodydropped's Avatar
Re: Car dies after using N2O??!! Help?
check your plugs, a friend of mine had this happen today and we found it was bad plugs and 1 wire.oh and his plugs were a week old,so check yours even if you just put new ones in.
Old Apr 12, 2005 | 10:06 PM
Black1995Z's Avatar
Oh god, thats the last thing I want to do... plugs. UGH! Even though its not misfiring?
Old Apr 12, 2005 | 10:10 PM
MakoLS1's Avatar
if your not already useing colder plugs that could be the reason right there. On LS1s yu have to use autolite 605s or ngk tr6s. Probabily the same with LT1s.
Old Apr 12, 2005 | 10:47 PM
and if you need new plugs,from what ive heard here so far. you can use autolite 103's or 104's or ngk i think the part# is 4177 or tr6. im using the 103's and i belive they are two steps colder than stock.
Old Apr 12, 2005 | 11:01 PM
Black1995Z's Avatar
I have TR6's. I guess I have no choice but to take them out and inspect
Thanks for the advice, friends.
I also noticed my car idles SLIGHTLY rough, is this from having colder plugs?
Old Apr 12, 2005 | 11:12 PM
really?mine idles smooter.hmmm weird. maybe you should also check for vacume leaks.i had one on the check valve on my brake booster that made mine idle really low and shut off sometimes.something to do with a back fire in the intake and it cracked the check valve.well thats what i was told anyway.
Old Apr 12, 2005 | 11:27 PM
Black1995Z's Avatar
Good thinking! I'll look tomorrow see if I can find anything.
Thanks for the fast replies bodydropped.
Old Apr 13, 2005 | 08:52 AM
let me know how it goes.
Old Apr 14, 2005 | 04:17 AM
13sectransam's Avatar
Mine also idled smoother with 104s as well.
bfmv13trivium
Jan 14, 2015 09:57 AM
ModdedNerd
Dec 18, 2014 10:52 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
