anyone have the dyno tune kit?
Old Apr 11, 2005 | 11:15 PM
nonojoe66's Avatar
hey im thinking about doing about a 100-125 shot on my mostly stock motor, i was looking at buying a NX kit because i read that they were realy good quality, but a little pricey. i have been seeing stuff about the dyno tune kit and it seems too cheep to me, anyone have it? anyone have problems with it?
Old Apr 13, 2005 | 02:38 AM
Wicked93Z's Avatar
Re: anyone have the dyno tune kit?
No problems with it yet. Install was pretty easy. I think the biggest problem for me was deciding where to mount the bottle. I have it hidden in the spare tire area, with a remote opener. Customer service was really great. I enjoy it a lot. Only thing that I changed was when I bought the purge kit. I went out and bought a brake line to replace the plastic tubing. Other than that, everything is great!
Don't forget to factor in costs of other safety devices (FPSS, Window Switch, Etc..), and what other misc items you want.
Old Apr 13, 2005 | 02:10 PM
Dean77's Avatar
If you compare the kits side by side you will see the Dynotune kit is equal to and for some components better quality than the NX kit.
http://www.speedshop.org/store/scrip...?idproduct=110
Dynotune sells using the Dell model - direct to customers with no distributors. This typically saves 25 - 40 % on the cost.
Compare the kits side by side and judge for yourself!
Good Luck!
Dean
Old Apr 13, 2005 | 08:08 PM
Wishmaster's Avatar
are they reated the same as NX kits? same output to the wheels? within 2% as NX claims.
Old Apr 13, 2005 | 09:08 PM
Dean77's Avatar
If you use the same size jets you will get similar power. The Dynotune kits are rated at the motor as drivetrain loss varies from car to car. If you have a 4l60E or a Turbo 400 your drivetrain loss will be different. If you have a 12 bolt or a stock rear end your drivetrain loss will be different. If you dyno a car with 15" wheels and switch to 18" wheels your numbers will change.
Hope this helps!
Dean
Old Apr 13, 2005 | 10:45 PM
nonojoe66's Avatar
is the quality of their stuff realy as good as NX? anyone thats not a dyno tune distributer? lol
thanks
Old Apr 14, 2005 | 07:35 AM
Dean77's Avatar
thanks
THis link has some more info for you
http://web.camaross.com/forums/showthread.php?t=334303
Actually you will not find any distributors as Dynotune sells direct, same marketing strategy as Dell computer, just on a much much much smaller scale Thats how they offer the quality they can at the price they can.
Dean
Jlo
Feb 3, 2015 09:41 PM
feraldrood
Feb 3, 2015 03:57 AM
chevysam
Jan 16, 2015 07:45 PM
SC97TA
Sep 15, 2002 01:10 AM
Burn_Out
Aug 18, 2002 08:49 AM
