bottle warmer necessary?
Old Dec 7, 2003 | 04:13 PM
juiced_lt1's Avatar
Heres an equation: PV=nRT the gas law. Seems at constant volume, if you spray 5lbs of a 10lb bottle, you'll only have 500psi left if you fill the bottle to 1000psi originally. (if not using a bottle warmer. Is that right?
Old Dec 7, 2003 | 04:22 PM
Josh-'04 GTO's Avatar
Pressure in the bottle will vary based on ambient temps. Regardless of volume, liquid in the bottle will boil until the pressure in the bottle is enough to stop the boiling. On a normal 65 degree day, you'll probably see around 600-650 psi with 5 lbs of nitrous in the bottle. With a heater, 1000 psi is no problem.
Old Dec 9, 2003 | 10:23 PM
SmokinZtires94's Avatar
Even though I live in Sunny So Cal ...I am still planing on buying a bottle heater ... looks like my bottle mounted gauge will stay and ANOTHER N2O gauge will have to be bought .... damn ..... if anyone asks, getting a nitrous kit is like opening a can of worms ....... or should I say bottle ?
Old Dec 9, 2003 | 11:53 PM
TRIPLE G's Avatar
I live in south west florida and i use a automatic bottle heater. It really helps maintain bottle pressure.
Old Dec 10, 2003 | 08:09 AM
rskrause's Avatar
Moderator
I think that keeping the bottle pressure consistent (at ~1000psi) is vital to the safe and effective use of N2O. So, you need a bottle heater and a pressure gauge, IMHO.
Rich Krause
Quickss96
Jan 29, 2016 05:56 PM
weedog
Aug 15, 2015 08:23 PM
zFrank
Aug 12, 2015 03:46 AM
Boss002
Jul 9, 2015 03:33 PM
