BMN Window Switch help
I'm finally starting to get around to put the HSW wet kit in my car. As of now I'm planning on using a BMN window switch but I cant find BMN's website or find any intallation/ programing instructions as I lost mine. Any help would be appreciated.
Also what better options do I have and what are you guys using for timing control?
-Stephen
-Stephen
-Stephen
-Stephen
sorry but I do not have instructions for the BMN switch but I do have a base wiring diagram
B will be power to your solenoids instead of the Zex box
Rest of the system
Please let me know if you have any questions
For timing controls there are a couple different options....do you currently have an ignition box?
Would you just recommends saying **** it and save up for a 685?
Dave.. I'll be def calling you in the next week as i need some parts 2 complete the set up.
For a simplified install yes...or you could still get the 685 as it the most cost effective way of adding an upgraded ignition and timing retard and use the BMN window switch to control the window switch and gear lock out.
Or you could sell the BMN to offset some of the cost of the 685
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
