Blowdown tubes?
Old May 29, 2004 | 08:22 PM
"White Knight"'s Avatar
Blowdown tubes?
Alright the only thing keeping me from going nitrous is the blowdown tube rule..........I think i know what they are.......aren't they just a tube that directs the nitrous out of the car if bottle breaks or something?? I just don't want to cut a hole in the bottom of my car. So tell me all there is to know about blowdown tubes
Old May 29, 2004 | 08:45 PM
RacinLT1's Avatar
they are required for open cabin cars. they vent the nitrous out incase the pressure relief valve lets from excess pressure.
Old May 30, 2004 | 12:01 AM
If you have the bottle in the hatch well, there are two large rubber plugs sealing holes in the bottom of the well. I suspect there is also a drain plug in the spare tire well. You could rig the blowdown tube to exit through one of those.
Not sure why you are concerned about drilling a small hole in the floor..... it's not like these are some sort of rare, exotic cars that are going to have some sort of future resale value. I drilled a small hole in the hatch well for a "bulkhead" fitting, and connected an -8AN hose. You can see the rubber plug in the floor a few inches in front of where I put the fitting. If I put the carpet back in, you'd never know the hole was ever there.....
http://cjcfo.fbody.com/members/injun.../DCP03655a.jpg
Old May 30, 2004 | 09:02 AM
Loadre's Avatar
Look in my sig and it has a couple pics of the blowdown tube routed through the grommet the in foot well.
Old May 30, 2004 | 09:25 AM
Fuels94TA's Avatar
I got mine exiting out the spare tire well threw the rubber grommet.
Vinny
Old May 30, 2004 | 07:34 PM
That is a good idea......i forgot about that grommet in the spare compartment........how are your guys' bottle's mounted? Straight up? can i put it in the spare compartment? Does it have to be mounted a specific way?
Old May 30, 2004 | 10:20 PM
Fuels94TA's Avatar
It's a straight forward install but it will only work's for a 10# bottle, not the 15#. I have mine in there but your going to need to fab a bracket and drill some hole in the tire well to secure the bottle down. Now this worked for me cause this is not my daily driver so I don't need my spare tire, if this is your daily driver think about it before you'll loose your spare.
Vinny
Old May 31, 2004 | 04:15 PM
JJJ93z's Avatar
You can mount the bottle upright?!?!? did not know that , i took your advice that you left about rotating around my bottle , but that looks sweet mounted like that, did you have to bend your syphon tube? have you had any probs not getting a good "hit". thanks
Old May 31, 2004 | 08:32 PM
The bottle is tilted forward... it just doesn't show in the picture. That puts the siphon tube at the lowest point. But I never pull more than 2 or 3 passes out of a single 10# bottle, so I never run it low enough to run the risk of uncovering the siphon. Remember, as you pull the liquid nitrous out of the bottle, some of the nitrous in the bottle has to vaporize to fill the "empty" space created by using up the liquid nitrous. When that liquid vaporizes, it cools the remaining nitrous, and reduces the bottle pressure. When the level in the bottle is low, you get too much cool down on the nitrous and too much pressure loss by the end of the track. It's not a problem if you are running a 100-shot, but when you up it to the 250-300HP range, its an issue.
Old May 31, 2004 | 09:35 PM
I'm a little confused on the siphon tube thing. Is it at the valve part? So i would have to fill the bottle more if i mounted it upright? Someone explain the whole nitrous flow to me......is there a tube that extends to the bottom of the bottle? You want the liquid right?
Old May 31, 2004 | 10:26 PM
Loadre's Avatar
Yes there is a tube at the bottom of the bottle. As Injuneer said, as long as you don't run the bottle too low, it doesn't matter what angle it's at. For most people a regular angle (created by the brackets) is best to get the most out of each tank.
Old Jun 1, 2004 | 07:39 PM
SDAKOVIC's Avatar
check photos in my sig. page 1, fifth photo down in first
column shows blow down tube.9th photo down in same column shows outlet of blow down tube using a "AN" thru bulkhead fitting #8
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
generaldave
Sep 25, 2015 06:48 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
