Best system....need a rec.
What is the best systen to run on an vic. intake with a 4150 mount plate?
I was checking out the new ZEX system with the perimeter spray...looks pretty good. Direct port is going to be too much trouble for the level I want and would require to much fab work that I do not want to do, b/c my injectors are in the way.
So whats the best 4150 plate system out? for around a 200 hit
I know one of the big magazines did a n20 plate dyno comparison. The name is probably slightly off, but speedtech or something with the word speed won every time. You can search for a similar topic on ls1tech.com and see the exact name. Results of the test were posted in the thread I believe.
.jpg)
