Bending a blow down tube??
Old Feb 8, 2007 | 04:44 PM
97s10ondubs's Avatar
Is it possible to bend a blow down tube w/o breaking it? I have 180 degree one from a friend, but i need it more at a 90 to get it through the hole in the passenger wheel well. He told me NAPA has a tube bender or something, anyone have experience?
Old Feb 8, 2007 | 08:52 PM
LT-x7's Avatar
Yes it's possible. Lots of places have tubing benders in stock including NAPA. Just make sure you get one than can bend 1/2" tube because some only go up to 3/8".
Old Feb 8, 2007 | 11:38 PM
jsetzer's Avatar
I have bent them small amounts by hand, I wouldn't do a 90 without a tool of some sort. Also you can get just the tube fairly cheap @ $20.
Old Feb 8, 2007 | 11:44 PM
Daniel6718's Avatar
if your going to bend it without a tool get something round and work it into the bend you need...
Old Feb 9, 2007 | 02:44 AM
2000GTP's Avatar
I would use a tubing bender, I tried bending one by hand and lets just say it didn't turn out so well.
Old Feb 9, 2007 | 07:38 AM
69z-28's Avatar
heat it up and bend around round object..... or tubing bender like said
Old Feb 9, 2007 | 09:20 AM
Ray@NitroDaves's Avatar
mihgt be close to the price of the tubing bender...
http://www.nitrousoutlet.com/catalog...roduct_id=2517
but yes as long as you have the correct bender they can be reshaped.
Old Feb 9, 2007 | 02:12 PM
Yea i actually explained it backwards, he has a 90 degree, i need to bend it to 180, my bottle is horizontal and the hole is in the floor, so it needs to be straight off the bottle to the floor.
Old Feb 9, 2007 | 02:25 PM
will be much easier to bend a 90* into a 180* than vice versa...as far as new ones they are the same price
Old Feb 9, 2007 | 04:27 PM
Replace the "tube" with an -8AN hose and a bulkhead fitting in the wheel well.
Old Feb 12, 2007 | 11:15 AM
jsetzer's Avatar
I don't think they would actually stop me from running, but I once asked my track about doing this. They said it had to be avaiable from the manufacturer of the kit. (NX in my case)
Do you think this would fly for a visual inspection with the bottle on the tunnel?
Old Feb 12, 2007 | 11:47 PM
I use an SS hose on a bottle located in the lower hatch well, and never had a problem with tech.
Old Feb 13, 2007 | 12:49 AM
speed_demon24's Avatar
Just heat it up and slowly bend it a little at a time. . And I had my bottle in the spare tire area, and had to use heater hose to get it to run out of the car and moroso didn't say anything to me about it.
Old Feb 13, 2007 | 10:50 AM
http://www.nitrousoutlet.com/catalog...roduct_id=1116
this is an example of the stainless line blow down tube....
Old Feb 13, 2007 | 01:25 PM
That's a lot of money for a blow down tube though.
