Battery Relocation & Nos Setup
Old Jun 27, 2007 | 05:23 PM
dutss707's Avatar
Would like some advice as to how I can relocate my battery to the
trunk (95 Z28), and install NOS somewhere, so it is safe and legal (?)
The spare tire setup works not sure I want to take a chance on
expecting no flat tires in the future.
1995 Z28 Red/Black Ttop: A4: AFR head; compcam 224-230" MSD Billet
LT1 Dist. EWP: 58mmHolley TB" Global West Traclink Torque ArM.
Spohn A-arms/upper and lower balljoints: K-member Tubular Crome Moly.
BeCool RAD, etc.etc.etc. too much to list.
Old Jun 27, 2007 | 07:32 PM
HardcoreRM125's Avatar
Safe - If it is set up properly, with the appropriate safety switches and such. And no, it will not make your car explode like on TF&TF.
Legal - As far as I know, it is legal to have on the car. Illegal to USE on the street. But prove you sprayed it ? Or at least this is what I was told.
Old Jun 27, 2007 | 10:16 PM
Boosted_Z28's Avatar
WHen you say "legal", are you refering to local vehicle laws or sanctioned racing rules?
Evidentially, some vehicle laws do not allow a person to actually use a nitrous system on public roads, so if you are concerned about that, you should probably check with your local law officials (yeah right!!!)
There are no real concerns with having a nitrous bottle and automotive battery mounted in close proximety to one another, BUT ther is a concern with having a battery mounted inside the passanger compartment if it is not properly vented to outside the car. In other words, you should only mount the battery in an "approved" battery box and ensure that it has been propery vented as a battery lets off explosive gasses when it is being charged and has the potential to explode, given the right conditions. I believe Moroso makes a blue battery box that is NHRA approved as well as Taylor. If you plan on racing the car at the track, they will also require a "PROPERLY" installed battery disconnect switch in order to pass tech.
The nitrous tank should have the proper NHRA blow down tube and bottle fitting and be vented outside the vehicle.
I have seen people fit both their battery and nitrous bottle in the spare tire well, but have not seen them be able to fit the battery into an approved box when locating it there.
Here's a picture of my set-up. Hope it helps some. Sorry it's not a real clear picture.
Old Jun 27, 2007 | 10:51 PM
As far as "legal", check your local laws. Here in NJ, you need a permit to possess N2O..... not because its used to produce HP, but because it is considered a controlled dangerous substance under NJ drug laws.
Old Jun 28, 2007 | 11:36 AM
Ray@NitroDaves's Avatar
Here are some pics of my setup
BMR Battery tray...legal if you are using a sealed battery
Bottle is mounted on the transmission tunnel behind the center console
Old Jun 28, 2007 | 01:27 PM
Jlo's Avatar
Jlo
wow that sux, I guess here in Texas thing are really different, at least here in south texas..
Old Jun 28, 2007 | 01:48 PM
Not really all that bad.... you fill out a form, check the "race vehicle" box, and send it into the State with $20. They send you the permit back in a few days.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DSMKilla
Jun 11, 2015 05:02 PM
Lt1son
May 27, 2015 10:35 AM
dylan1303
May 22, 2015 12:24 PM
