Avoiding the dangers of N2O
I have heard that both types of N20 induction have their dangers. I would like to know what a person should do to avoid those dangers to minimize the risk associated with using N20.
I've been told that with wet kits, you have to worry about nitrous puddling?
And I've head the with dry kits you have to worry about injectors "locking"
What other dangers are there to watch out for, and how does one get past them?
Re: Avoiding the dangers of N2O
with a WET kit, to ensure you dont encounter "puddling", simply get a purge to make sure the n2o is there and clear the motor out before making a pass. in other words, rev the motor a couple of times before you run to clear out any fuel that might have puddled, then purge, and run.
with a DRY kit, to MAXIMIZE safety, your prolly gonna want to get bigger injectors, aftermarket fuel pump and FPR. the "locking up" your reffering to occurs when the stock injectors are being pushed to their limit. in othe words, your trying to flow too much fuel through them.
personally, i like the WET kits better and would never put a DRY kit on anything i own. i just dont like the whole concept. that, and there alot more expensive- either you buy a kit that already has the injectors, pump, etc which THEY WILL add into the price of the kit, or you end up buying those parts aftermarket and individually. either way , its more expensive. ive also talked to people who have run both and they say that the WET kits were more effective and efficient.
i put my WET kit together for under $400, have dropped a little over a second in the 1/4 SPINNING, and have had ZERO problems. just my opinion
Here's a couple of sites that may help to answer your questions.
http://www.toyotacelicas.com/informa...icles/n2o.html
http://www.go-fast.org/z28/new_to_nitrous.html
A lot of stores are closed because the holidays so I can't hear from them, but I want to know if the direct port setup is a lot more for a wet kit? Or does it come with a wet kit. I am still new to this.
A typical wet kit will come with either a nozzle or a plate. A direct port system is going to be a lot more pricey, and not a part of any "kit" that I know of. It's much more of a custom setup.
Dave
Dave
gelbza
Jul 12, 2015 08:10 AM
