How much should i spray?????
Old Dec 15, 2002 | 01:58 AM
stik6shift98's Avatar
mods in signature
Old Dec 17, 2002 | 09:54 PM
dam*n u guys are helpful
maybe ur misunderstandin....im sprayin 100 and want more is that a good idea or not.....better
Old Dec 17, 2002 | 10:55 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Get a fuel pump in there(255 intake) and spray a 175 shot(wet), just make sure your air-fuel is ok
Old Dec 17, 2002 | 11:04 PM
175 damn and the nym car will right.......
u sure??????????
Old Dec 17, 2002 | 11:22 PM
PNYKILR's Avatar
It's not like it that much bigger . I've never had a problem, when i was stock. I did have 30lb injectors in there aswell as a 255 intank. Must have sprayed that thing 200 times.
I know it's a different car and all, but I've seen so many 5.0's spraying a 175 shot with there factory 19lb injectors and a upgraded fuel pump.
Old Dec 17, 2002 | 11:59 PM
thanks.......
anyone wana second that...or......
Old Dec 18, 2002 | 08:59 AM
COMNBYU's Avatar
look man, you can go bigger than a 100shot. ive seen guys go a 175 on a LS1 with the stock fuel system. as far as your motor holding up, dont worry about it. ive heard of guys spraying 250+ on a stock bottom end.
i dont how entirely true that is, but, as long as your planning on staying under a 200shot, i wouldnt worry about anything.
JUST MAKE SURE THE FUEL IS THERE!
good luck
Old Dec 18, 2002 | 10:04 PM
Flyin t/a's Avatar
Hmm I'd stick with no more than a 150, I wouldn't go any bigger than that with out a progressive controler. Do you spray on the street at all? hehe just wondering I live over in naperville and have seen your car around a couple times, just wanted to know in case I happened to run into you.
Old Dec 19, 2002 | 01:28 AM
chesee48's Avatar
Dont listen to Brad...hes a retard
j/k
Anyways wheres the pics man??/
Old Dec 19, 2002 | 08:29 AM
well considering i havnt been to the track and got my bottle filled 7 times.......what do u think
and cheese48.......i was sick.... and the tires are under some stuff in the garage and its cold as hell.....ill get them asap
as far as the shot.........im thinking 150?????
thanks
Old Dec 19, 2002 | 11:58 AM
rpm4lalo's Avatar
Get some 125, 150 and 175 jets for your NX kit and work your way up monitoring fuel.
Old Dec 19, 2002 | 04:46 PM
i think i have those nozzles........if not where and how much are they....
Old Dec 19, 2002 | 04:50 PM
COMNBYU's Avatar
their JETS that go IN your nozzle where the fuel and n2o hook to the nozzle. you can get them at your local speed shop for prolly $5-8/pr, or you can get them from Summit for 2.95/pr.
FYI, you dont need to change the nozzle.
Old Dec 19, 2002 | 05:08 PM
i ment jets.srry
Old Dec 19, 2002 | 07:37 PM
Flyin t/a's Avatar
j/k
D!ickhead were you been.
