Autometer air/fuel gauge not working right...need help?
Old Aug 28, 2002 | 10:56 PM
asianice25's Avatar
Angry Autometer air/fuel gauge not working right...need help?
I just put the juice back in and i put my air/fuel gauge in. i had it in the car before with powe, but i neve hooked it up to the o2 sensor. it was like thi for about 5 monthes, and then i took it out for about 2 monthes. so now it runs around stoich at the start, but it falls, and falls. pretty son its running below the lean part and sometimes flickers in the red part. what is going on? is the gauge bad? i know i hooked it up right(used a o2 harness) and iknow is getting power...
Scott Parkinson
2001 Sunset Orange Z-28
SLP Loud Mouth Cat-Back Exhaust, LS1 Motorsports Intake Bellow, K&N Filter, MTI Clear Air Lid, Mass Air, 160 Thermistat, Power Programmer, 8.5mm Plug Wires, BMR Sway Bars, BMR STB, Competition Engineering Frame Ties, Lakewood LCA's and Panhard Rod, 125 hp Shot. Runnin low 12's all day.
Old Aug 29, 2002 | 06:24 PM
InjectedSS's Avatar
Post
whens the last time you replaced your o2's? more than likely you have bad o2 sensors, think about it, they have to stand over 600 degrees of heat all day when your driving. ive had a bad one right outa the box brand new once. check the other side and see if it does the same thing!
Joes96z
Dec 13, 2014 07:48 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
Burn_Out
Aug 18, 2002 08:49 AM
